Results 1 to 15 of 25
    alekseyms
    Guest
    Default Xentry OpenShell HHT DAS WIS EPC Starfinder Vediamo Monaco - Acronis 03.2021
    Xentry OpenShell HHT DAS SCN WIS EPC Starfinder Vediamo Monaco - Acronis 03.2021
    Image size 181 Gb.
    Computer requirements:
    • HDD or SDD > 240 Gb
    • RAM 4 Gb
    • Processor with support for virtualization technology (enable virtualization in BIOS).
    Acronis image with Windows 10 x64 Rus (by default) + English.
    Image of programs for the diagnosis, coding, and programming of cars of the Mercedes-Benz concern.
    This image contains all the software from various sources, including activators.
    The image is fully configured and working. Checked at 15 car services.
    The image contains everything you need to activate and configure yourself.
    The software package is already configured for MB Star C4 (Mercedes Star Diagnosis Compact 4).
    Programs in the image:
    • Xentry OpenShell 28.9.3.2 03.2021
    • DAS SCN offline coding (SDFlash 07.2018)
    • Vediamo 05.01.01
    • DTS Monaco 8.14.016 + projects 2019
    • EPC 11.2018
    • WIS 07.2020
    • StarFinder 2020
    • HTTWin on Hyper-V password: 111
    • Fdok
    • Manuals for Vediamo + Monaco.
    • COMANDDownloadManager login: DLM password: DLM
    • Selit
    • DisassembyAssistant.
    Current updates:
    • Xentry
    • WIS
    • Selit
    Previous updates:
    • firmware database for Vediamo and Monaco
    • HHTWin configured for truck and bus diagnostics
    • configured DAS Standalone, there is a shortcut
    • there is a shortcut to launch HHTWin directly
    • configured to work without errors Xentry Update Service - XUS, which includes more than 64 thousand factory firmware that can be downloaded for free upon request by clicking on the button in the program
    • Xentry update data is downloaded automatically without errors
    • DAS offline SCN is not applied since this assembly under the online flash folder needs to be renamed before applying the patch
    • there are Xentry patcher and blacklist, except the long key
    • DTS Monaco configured interface for SDconnect
    • the base of patches and activators for setting up and activating all programs with your own hands for free!
    If the error 2221-45 appears on the screen when starting Xentry, then in the path C: \ Program Files (x86) \ Mercedes-Benz \ xentry \ fusoko \ eclipse \ plugins delete the file com.daimler.xentry.diagservice_1.8.x. xxxxxxxxxx
  2. The Following 15 Users Say Thank You to alekseyms For This Useful Post:
    autocargo (13th August, 2021), electronistul21 (13th April, 2021), frizera (13th May, 2022), gonzoo1991 (7th August, 2021), hrmotorsport (7th December, 2021), kaasari (31st October, 2021), kesag (16th April, 2022), littleun2 (19th July, 2023), maruti (26th July, 2021), sasko007 (16th November, 2021), Stelaras26 (24th May, 2021), tigex (10th September, 2022), Toutancamon (6th October, 2022), vdiag (16th April, 2023), youberser (13th September, 2023)
  3. #2
    Mar 2019
    Where is the download link ?
    alekseyms
    Guest
    In txt file above.
    Apr 2016
    Hello and Thanks for your good work !
    Do you know if can be set to work with C6 passthru ?
    alekseyms
    Guest
    Hello. Yes, if you'll change Xentry Openshell to Xentry Passthru.
  7. The Following User Says Thank You to alekseyms For This Useful Post:
    bunicu86 (12th April, 2021)
  8. #6
    kasia ovi's Avatar
    Dec 2018
    poland
    very good job
  9. #7
    Mar 2021
    Special function works? With what? Key generator?? I need disable pedestrian system...
  10. #8
    May 2021
  11. #9
    Mar 2021
    link not working? help me please
  12. #10
    alekseyms
    Guest
    Updated link
  13. #11
    Oct 2010
    malaysia
    Will this work with C3?
  14. #12
    alekseyms
    Guest
    Quote Originally Posted by aet View Post
    No, for C3 you need to use 2014 version.
  15. #13
    Oct 2010
    malaysia
    Quote Originally Posted by alekseyms View Post
    Thank you kind sir
  16. #14
    Jun 2020
    Please i cant get text file somebody help me
  17. #15
    Aug 2021
    very good job
