Results 1 to 10 of 10
    Apr 2021
    Default Bmw e91 2.0d m47 edc16c35
    hello, my first post here (and eng isnt my main lang), im steel learning so please be patient and forgiving .
    im trying tune my car always alone and next lvl is make changes in ecu.
    so i want reed his controller on bench (not by bdm), bcs i heard its more safer, and my battery is ~12v (11.99-11.90 but normal working)
    like in this video https://www.youtube.com/watch?v=2aqa...l=ERAutomotive
    but i have litle bit different tools
    mpps v21 with this cable (in attachments)
    power supply (in attachments) 12v and 5A, i measure the tension and gauge shows 12.25v but in mpps program shows 11.99v
    and i dont know is it safe bcs should be ~13v
    i checked pinout edc16c35 here https://nat-corporation.com/DORABIAN...35-ecu-pinout/
    and i gonna put just 12v, gnd, and k-line, i dont need can h and can L (or i dont know something).
    i heards many things about mpps but by this tool i was read ecu from skoda (everything was good) and he correctly reading dtc code from this e91. (in attachments)
    and i think what i have to do when program ask for put off key and put on. i have some button on this cable, so its for it? (or like in this video, just turn off 12v and turn on)
    please answere for my questions and
    tell me what you think about this method and is it safe?
    regards
    Dec 2018
    Hi Frend. This button is used to turn on the power. Well let me tell you mpps is moderately safe. Because you have to count the checksum yourself. If you forget to do it and upload the file. This will block the ecu. How do you have the Cinska clon version. Sometimes you have problems reading and not uploading. Or it reads the file wrong. Galleto talks well with this driver. And it's not expensive anymore. Well, it depends on you how many times you will upload ecu.
  3. The Following User Says Thank You to elektronik325 For This Useful Post:
    Nace (7th April, 2021)
    Apr 2021
    yes its clone version, im gonna upload my ecu maybe 2 times,
    i will be edit map by ecm titanium
    so this program count checksum
    so, better dont try by this mpps?
    Dec 2018
    I have a bad experience with clone. So I would do it after bdm. Just be sure to double-check the bdm connection. In order not to turn the adapter 180 degrees. Because you're gonna burn the computer. But nah you have a sure reading.
  6. The Following User Says Thank You to elektronik325 For This Useful Post:
    Apr 2021
    Someone using mpps here?
  8. #6
    Dec 2018
    Quote Originally Posted by Nace View Post
    Sometimes I use. Ori version. You can forget Chinese maple. You want it, invest in galleto and it will be ok with this ecu
  9. The Following User Says Thank You to elektronik325 For This Useful Post:
  10. #7
    Apr 2021
    You mean galetto v54, or 1260 is enough? And i can do this by obd?
    I cant find this anywhere in my country, just on allieexpres
  11. #8
    Dec 2018
    I have sent you all the valuable information on prive.
  12. The Following User Says Thank You to elektronik325 For This Useful Post:
  13. #9
    Apr 2021
    my file ..
  14. #10
    Dec 2018
    Default Bmw
    Try the solution. Thenks+REPUTATION=Pass in prive
  15. The Following User Says Thank You to elektronik325 For This Useful Post:
    Nace (9th April, 2021)
