Results 1 to 8 of 8
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    Default Synchro DDE BMW X3
    please repair eep fix 95640 BMW X3 ecu 0281014175 .. have DTC 4A42 try syncro FVDI clone ... bat it replies, which it cannot synchronize!
    ..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
    Gammoudi's Avatar
    Dec 2017
    ECUS
    POST EWS DUMP
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    .... see file EWS4.3
    Gammoudi's Avatar
    Dec 2017
    ECUS
    the two fils are ok and synchro is ok check with another key
    centrohifi's Avatar
    Apr 2011
    From Italy .......
    created new key ... EWS recognizes all keys ... changed EWS ... error always remains in DDE. Added cable between pin 4 (EWS) and (DDE) 10 ... problem remains ..
    qwertyuiop12's Avatar
    May 2013
    Hi,ISN EWS-DDE=OK,but rolling code between EWS and ECU NOT Ok,you need make sinxro Inpa
    PierreTheron's Avatar
    Centurion,South Africa
    thnks clever mate
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by centrohifi View Post
    Did you solved?
    Sent from my 5033F using Tapatalk
