Laguna 3 2010 M9R edc16cp33 injectors code and Engine fans not stops
Results 1 to 4 of 4
    mexanico1971's Avatar
    portugal
    Default Laguna 3 2010 M9R edc16cp33 injectors code and Engine fans not stops
    I got this Renault laguna 3 from 2010
    Engine M9r width edc16cp33 that cank"s and not start
    I the ecu dtc 062F ECU memory
    and DTC0611 injector initialization
    Car was on road and died
    Fuse width the Diode was blow and engine cooling fans not stop
    I get another ecu same part numbers , but wont me let me code injectors and car stil not start
    And now I have DTC 0611 injector initialization
    and thermocouple circuit 1,2,and 3
    any experience similar problem ?
    Any one got a full service workshop manual for this engine or car ?
    Best regards
    take care
    My work is my life ART TECH GARAGE
    Aug 2010
  3. The Following User Says Thank You to ascouser For This Useful Post:
    mexanico1971 (14th April, 2021)
    portugal
    Can any one please make eepron virgin for this ecu ?
    And what the best way to write code injectors ?
    Thank"s in advance
    Take care
  5. The Following User Says Thank You to mexanico1971 For This Useful Post:
    harveystewart (7th August, 2021)
  6. #4
    portugal
    Solved
    The ecu I buy , have the same numbers in the label , but software was different !
    I copy all , and clip done the rest .
  7. The Following User Says Thank You to mexanico1971 For This Useful Post:
    Meat-Head (16th April, 2021)
