Page 2 of 9 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 130
  1. #16
    Aug 2018
    hello, can you give me password? thank you in advance.
  2. #17
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by kosta2302 View Post
    You cant be serious :P :P
    Just read ONE post before yours.Then read the second post in this thread..
    If i Helped you,use thanks and rep button to thank me back
  3. #18
    Jun 2015
    THANK YOU
    PM PLEASE
  4. #19
    Oct 2018
    romania
    Thanks friend.
  5. #20
    dehacko's Avatar
    Feb 2018
    SK
    mihaiti I have same problem. offline mode in win7 32bit: after connect loopback adapter soft won t start. I try on few second start soft in online mode and program start well. I will try offline with loopback on second notebook via win 7 64bit and rep.
  6. #21
    Jun 2019
    Ukraine
    pass please.....
  7. #22
    dehacko's Avatar
    Feb 2018
    SK
    i try win 7 64bit not work offline mode with loopback adapter
    win xp not support
    any advice?
  8. #23
    fantomel's Avatar
    Mar 2009
    Us
    make your phone hotspot even without data active and program will work offline or use a virtual ethernet emulator.
    If you like my post and it helped you please press THANKS.
  9. The Following 3 Users Say Thank You to fantomel For This Useful Post:
    autotuner (10th May, 2021), fordmidabil (25th June, 2021), mindafuttu (2nd December, 2021)
  10. #24
    Feb 2021
    Quote Originally Posted by fantomel View Post
    This option also has no effect. That's why at the beginning I asked if the software needed a connection to the developer's server to complete the file.
  11. #25
    dehacko's Avatar
    Feb 2018
    SK
    hotspot solution is not work
  12. #26
    Aug 2018
    pass pls and thanks in advance
  13. The Following User Says Thank You to zmiikata For This Useful Post:
    serjikel (16th July, 2021)
  14. #27
    Nov 2011
    ChipLand Italy
    Guys I just found out that the Internet connection is real!! Be careful.
    After Install davinci my firewall was going off often never happen before, so I have launched netstat monitoring in with surprice I notice a weird communication with a external IP.
    Then I have monitored the communication with Wireshark and I notice that there was a big movement of data and packet out.
    I found out that the software once is installed enable the remote desktop in the registry , SYSTEM\CurrentControlSet\Control\Terminal Server and the protocol TFTP
    The hypothesis are 2, First who craked the software is collecting file and information of people that use it. Second is possible that who made davinci is monitoring pcs and users
    Datas and Informations are leaking out, check the port 23 and if it is open close it!! Run the in the CMD as Admin dism /online /Disable-Feature /FeatureName:TelnetClient
    To close Telnet!!
    I know not with what weapons
    World War III will be fought, but
    World war IV will be fought whit
    "sticks and stones"
  15. The Following 10 Users Say Thank You to d3v1l For This Useful Post:
    42xqn2803o (9th May, 2021), Col19 (23rd May, 2021), faycal99 (23rd April, 2022), gege974 (11th May, 2021), gia (14th May, 2021), GianniNOS (13th May, 2021), hmagga (18th March, 2022), KADE007 (8th May, 2021), simplo (21st April, 2022), Totonio (27th December, 2022)
  16. #28
    Jul 2019
    Espaņa
    pass please
  17. #29
    fuzz1's Avatar
    Jul 2019
    Anyone been successful using that software for adblue removal?
  18. #30
    Jan 2018
    hi can i have the pass please?
