Results 1 to 9 of 9
    Mar 2020
    Default Weak power while regeneration
    Hi guys,
    I have a problem with a tune for a Seat Leon 2008 2.0 PD 170HP.
    On stock file there is no problem with regeneration.
    But with tuned file there is very much power loss while regenerating...
    Like 20% less power but it feels sometimes even less...
    Maybe there is not enough fuel injection because the regeneration also takes very long with the tune.
    Hope someone can tell me what is wrong
    I attach ori and tune.
    Also can someone tell me if EGR is off in the tune?
    Thanks so much in advance.
    Mar 2020
    Sorry I had the wrong file attached...
    Now is correct.
    Mar 2020
    These are the correct files.
    I am sorry...
    treble6's Avatar
    Nov 2008
    here is your file to try,pm for password
  5. The Following User Says Thank You to treble6 For This Useful Post:
    audia4b7 (8th April, 2021)
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Pass In PM
    Chiptuning File Service 24/7
    Thanks+Rep If I helped you!
  7. The Following User Says Thank You to Johnsy1998 For This Useful Post:
  8. #6
    Mar 2020
    Thanks so much Johnsy, your PM box is full though...
  9. #7
    Mar 2020
    Sorry but not solved..
    I got no pass for first file and second file seems to be ori with egr off...
  10. #8
    Mar 2020
    If someone could help me try to fix my problem I would be very thankful...
    Something has to be wrong in the mod file.
  11. #9
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Here you go, this should fix the problem
  12. The Following User Says Thank You to Johnsy1998 For This Useful Post:
    audia4b7 (9th April, 2021)
