you have to wait for gpt cable mate..and recover will be ok
First of all, thanks for your help friends.
The initial problem was that when programming an EDC17C60 with a KTM Bench it stopped over 12% and part of the internal flash of the mic is erased.
The KTM Bench continues to identify the ECU but it won't let me read or write because it gives me an incorrect password error.
So I wanted to try to recover the ECU with the Ktag, but connecting the ECU by pinout and Boot mode does not recognize it and does not allow me to load the backup.
This is why I thought that I could communicate through that port as in the EDC16 to be able to recover the ecu. But if you tell me that it is the same as connecting the cables to the pins of the ecu, then I imagine that it will not communicate with the katag even if I use the adapter.
If my post was helpful press Thanks button!!
when you try to do that you use protocol menu or you go on brand type?
when you plug the pins from cables to ecu,there is any strengh or go easy?if it go easy try to close a little bit the pins from the cables
marcolr (14th April, 2021)
Hi Frend. Did you read your beckup before you started uploading Ktm? And for Ktag you need to do boot mode. Open the driver and connect the boot pin to pin 6 of the processor (gray cable with a crocodile clip), otherwise you will not be able to read it.
Yes, I read backup before had any problems. An yes, I already open the ecu and connected boot mode to try recover with Ktag. And I tried with module 53 of KTM Bench using boot mode and the KTM connect with the ecu but canīt read or write because the problem of password
And how did you take the ktm reading. Did you write down your password? If so, try to give him this file and he should upload the ori read file. I noticed that Ktm has a problem with the checksum of the file. And when you upload a modified file, it will not be able to upload it correctly. If you don't have a saved password. It remains for you to upload the Ktag. directly beckup. If you try to read it, it won't go. And separately uploading only immediately beckup.
I read the files (flash and eeprom) by KTM Bench without open ecu. After I write a modified file and all was well. The car start and runs perfectly, but after a few starts the car stops to start because of the problem that you say. Then I try to upload the original file to start the car and was here where the KTM stops in the middle of process.
I donīt have the password because I donīt read it before.
With Ktag I already tried all (read full backup, read flash, read eeprom, write flash, write eerpom and write a full backup of other ecu with identical part number because I donīt have full backup of this ecu) and same result in all tries. The Ktag canīt comunicate or
identify the ecu.
I get it. It's strange since he uploaded and it was ok for a pair of start car. I would say it's the driver's fault. Since you didn't open the ECU sooner, you don't have one to beckup. Because katak tracks it via GPT and it must additionally be in boot mode to pin 6 of the processor gray katag boot cable. Otherwise it won't be read by katagas. Well, it's not good that you don't have the processor password. And if you connect the driver to the car, do you still connect?
