Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    marcolr's Avatar
    Default EDC17 BDM pinout
    I need the BDM port pinout for connect a EDC17C60 to a KTAG.
    I have bought the 14P600KT04 adapter and the 14P600KT03 cable. But they take several days to arrive and I need to recover an ECU urgently.
    Can someone pass me the pinout from the BDM port of the ecu to the DB15 connector of the Ktag and where to connect the boot cable?
    Thanks in advance
    If my post was helpful press Thanks button!!
    Apr 2013
    Is this cable in question?
    — GREEN — CAN L;
    — ORANGE (2 шт) — VKEY;
    — YELLOW — K LINE;
    — RED (2 шт) — VECU;
    — BLACK (2 шт) — GND;
    — PURPLE — VPP;
    — WHITE — CAN H;
    — BROWN — RESET;
    — GRAY — BOOT;
    — BLUE — CNF1.
  3. The Following User Says Thank You to 2xded For This Useful Post:
    marcolr (9th April, 2021)
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by 2xded View Post
    — GREEN — CAN L;
    — YELLOW — K LINE;
    — PURPLE — VPP;
    — WHITE — CAN H;
    — BROWN — RESET;
    — GRAY — BOOT;
    — BLUE — CNF1.
    Kess don't have DB15
    Apr 2013
    Are you talking about 14P600KT02 cable for Kess?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    I think so yes
    marcolr's Avatar
    No. I’m talking about pinout from EDC17 BDM port to Ktag DB15 port.
    Apr 2013
    Sorry, I misunderstood your question in # 1.
    Maybe this will help you?
  9. The Following 4 Users Say Thank You to 2xded For This Useful Post:
    ecufix (9th December, 2022), marcolr (10th April, 2021), mexanico1971 (4th April, 2023), tordu (10th June, 2021)
  10. #8
    marcolr's Avatar
    Thanks for your effort mate but or I explain bad or you don´t understand my problem.
    I need connect the ecu as in the last page of PDF "GPT PSA_2" that you uploaded, but I don´t have the 14P600KT04 adapter or the 14P600KT03 cable (the last two pictures that I uploaded in the post 6)
    Then I need the pinout for connect the ecu to Ktag (from BDM port of the EDC17 to DB15 of Ktag) and with this pinout, I can connect the ecu without adapter (by soldering cables).
    I already bought the 14P600KT04 adapter and the 14P600KT03 cable, but it´ll arrive in 15 days to my house and I need recover a faulty ecu.
  11. The Following User Says Thank You to marcolr For This Useful Post:
    2xded (10th April, 2021)
  12. #9
    Apr 2013
    I suppose the connections can be made with ordinary wires according to the diagrams from my post. This is certainly inconvenient, but possible, IMHO.
  13. #10
    marcolr's Avatar
    I need something like this picture but for EDC17 and Ktag. The picture is for EDC16 and Galletto.
  14. #11
    Apr 2013
    Does the tricore have a BDM port?
  15. #12
    Sep 2010
    Not. there are only pins that you can already find on the connector side (can bus, gnd, ign, vcc) there are no special bdm pins. Wrong way to recover ecu. It is better to describe your problem in detail.
  16. The Following User Says Thank You to proel For This Useful Post:
    marcolr (11th April, 2021)
  17. #13
    carmageddon's Avatar
    Italy
    NO
    BDM mode/pinout its ONLY for motorola mpc (edc16, me9, some siemens etc), not for infineon tricore
  18. The Following User Says Thank You to carmageddon For This Useful Post:
  19. #14
    Apr 2013
    How to explain this to a topic starter?
  20. The Following User Says Thank You to 2xded For This Useful Post:
  21. #15
    Sep 2010
    It is always better to ask people on the forum how to solve a problem instead of developing theories for a solution ... simply
  22. The Following User Says Thank You to proel For This Useful Post:
