you wont get help you have just joined expecting someone to help you without giving help to others good luck is all ill say
And we are not going to give you good quality tested tunes so you can try them then maybe pay after
you dont go into a shopping market and eat the food before buying it do you....
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
(DEMON DEVELOPMENT)
New Turbo or is it Just redone? Engine compression and timings are checked? If chain/Belt is New, did you check them after a few km again?
Values via vcds are ok?
Also Do this: https://youtu.be/ALf-8zJUY5k for your engine (cant find a english Version)
Some Problems will only Show up with higher Power and smaler issues will get bigger.
pal you really need to travel and get it on a dyno and tuned,the guys here just trying to give you advice.
no logs and you expect someone to adjust map to suit,very difficult.
"NO ONE IS AS DEAF AS THE MAN WHO WILL NOT LISTEN"
Best thing to do would be load a known file, or the same stage 2 you have currently now on and log with vcds. See if everything makes sense regardng to requested to actual values of the following:
Following channels will give you enough information to see what's going on:
Boost/load: 114, 115
fueling: 002, 246, 230, 031, 113
timing: 003, 020
Timing chain VVT: 091, 093.
Better to datalog and analyze before replacing parts blindly.
Cheers
here is the original file requested on private message.
Thanks for people who wants to help!
make logs and contact me i can make strong tune and will work but if car not good tell us and check car for repair
this car in stg1 all stock going to 250hp easy in stg2 275-280hp only downpipe and sport filter
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Which channels should i make logs ? Is it ok with vcds?
thanks.
