Originally Posted by
cokeaddict
So I read that it's possible to flash the ecu in my Saab 9-3 using either FGTech v54 or MPPS V12 or newer.
It seems that as my car is a 2005 then it will use the EDC16c9 ecu which lots of post suggest can't be read via obdII properly and a BDM read should be done ?
Anyway I just went out to my car and did a read with both MPPS v13.02 and also with FGTech v54.
I tried it as both Saab 9-3 and Vx Vectra with both tools.
I also did a read as EDC16C9 and EDC16C39 with both tools.
The MPPS didn't give have the option under Saab 9-3 to read the C9 variant, only the option for C39, so I did a read as a Saab C39 and also as a Vectra C9, both files are an exact match (checked with hex compare).
With FGTech V54 the 2 C9 reads (Saab and Vectra) again match each other, but both C39 reads failed, it gave me a warning about only being able to read 1 of the 2 map locations but failed to read either.
All files are 1.0mb in size, but the MPPS files do not match the FG Tech v54 files.
What confuses me, is that I read it was the C9 ecu that is hard to read via OBD, but the C39 isn't an issue ?
I also searched online and found a couple of BDM reads that match my SW and HW numbers and those bdm files are a match for my FGTech V54 obdII reads using C9.
So does that mean that the FGTech v54 did infact read the EDC16C9 via OBDII without an issue ?
Also does anyone have a good Stage 1 tune with EGR / DPF delete (no issues with either, but may aswell map them out before I get issue's) for my ecu for flashing (safely) with either MPPS or FGTech V54 ?
I noticed a couple of files have been posted on this board previously, but I do not have the password for the files (I have pm'd the users that posted them but no reply as yet).
Bosch Hardware Number: 1037372565
Bosch Software Number: 0281012247
Opel Software Number: AA
Engine Type: Z19DTH
1037372565P319_S83
I have attached a file from each sw.
Many thanks
