Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    Greece
    Smart pro have 11 euro token not 20. And for smart and twingo traffic is the safest tool. Silca write is not possible make damage. I have done a some and never have problem. Also never read for problem for smart pro.
    Στάλθηκε από το S31 μου χρησιμοποιώντας Tapatalk
  2. The Following User Says Thank You to kleidaras For This Useful Post:
    Faraday (25th December, 2021)
  3. #17
    Dec 2016
    Quote Originally Posted by kleidaras View Post
    Let me smile !
    Problem is not the tool , it's the process !
    Let me explain you :
    - 25 minutes method
    a) read flash & save it ( 20 minutes )
    b) errasse / virgin / delete PIN code read protection of BCM
    c) Add key
    - 3 minutes method
    a) virgin / delete PIN code read protection of BCM to read PIN code
    b) Pre-code new key if AKL or simply add key
    3 minute méthode is safe if you have no problem , but you have no backup in case of problem ( battery , OBD2 plug ... )
    11 € is good price if you need only one
  4. #18
    Greece
    Quote Originally Posted by TERMINATOR1000 View Post
    Let me smile !
    - 25 minutes method
    c) Add key
    - 3 minutes method
    Except if a 3rd method but you and me not know about .
    Silca write this.
  5. The Following 2 Users Say Thank You to kleidaras For This Useful Post:
    godfathertre (11th April, 2021), p1et (11th April, 2021)
  6. #19
    Dec 2016
    They copy to theft ( keydevice ) method & AVDI method ( R.E.T USE FIRST on Clio 4 ) , they're the last to use it
    No "master key" on Renault , this notice is simply an joke ! Tool made BCM T4 in virgin state to read PIN code , learn it with old key , add new key ( or pré-code new with tagKey if AKL )
    https://www.youtube.com/watch?v=MW8Z8kcUUAs
  7. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
  8. #20
    Hampshire
    Just done a 2019 traffic ,spare aftermarket remote key with smart pro,no pre coding,with jump pack on, it took around 4 minutes.
  9. The Following 2 Users Say Thank You to nazz2 For This Useful Post:
    Faraday (25th December, 2021), TERMINATOR1000 (15th April, 2021)
  10. #21
    Dec 2016
    Quote Originally Posted by nazz2 View Post
    Yes sir , pre-coding only for AKL situation ! like Clio4 2016+ AKL ...
