Results 1 to 10 of 10
    tunstyle's Avatar
    Default W210 220cdi Ecu Sync Need. 0281010041, A0245452832
    I have one mercedes w210 e220cdi with this ecu 0281010041, A0245452832.
    The car don't start, please any one check if this ecu files have any sync problem??
    Startet don't turn ON, ecu don't delivery +50 signal
    Thanks you
    tunstyle's Avatar
    Any help please?
    Jan 2020
    Ukraina
    HI.Try ....................
    tunstyle's Avatar
    Hi, same problem the starter don't work. Ecu is it damaged?
    Ezs tested +50 output to ecu signal OK, in ecu the output signal to k40 module nothing comes out.
    workshop
    what show DAS actual value?start enable?
    tunstyle's Avatar
    Quote Originally Posted by mercis View Post
    In start codition it show:
    Terminal 15 - Connected
    Terminal 50 Input - Connected
    Terminal 50 Output - Disconnected
    I have buy used ecu with same part number to test
    tunstyle's Avatar
    I post full backup for used ecu, i need help to virgin this eeprom please
    Jan 2020
    Ukraina
    Hi.Try.................
    tunstyle's Avatar
    Quote Originally Posted by Gesha Nemirov View Post
    Don't work, i have message "peramitrization not performed" in last step of programming
    tunstyle's Avatar
    Any help please, not solved
