Results 1 to 4 of 4
    Dec 2020
    Exclamation Diagnose citroen C3 with Delphi tool
    hello everyone ,
    i have a problem when i diagnose citroen C3 with a delphi
    the problem is that the tool will not be powered when I connect it to the obd plug (the LEDs remain off) (see the photo)
    I measured the voltage supplied by the obd plug and I found 12.4x volts; the ground is connected properly (pin 4 and 5); the power too (pin 16)
    i don't have other tool to test .
    is this problem with the car? or the delphi tool is not compatible with this car model?
    note: the delphi tool works fine with another car.
    thank you
    Hello, I've got the same problem in c3 1.4l hdi deplhi ecu. the obd haven't got plug good. the obd2 car moving when I plug delphi. Check obd2 plug
    or check with tester pin out 4-16 or 5-16 .
    I helped you press thanks
  3. The Following User Says Thank You to babouches For This Useful Post:
    Pezhoo (22nd May, 2023)
    Dec 2020
    Quote Originally Posted by babouches View Post
    thank you,
    but i already mention that i found a voltage of 12 volts between (pin 4 and 16) and between (pin5 and 16).
    dehacko's Avatar
    Feb 2018
    SK
    ben pins on the side (turn) on the delphi socket
