Here,write this as 93s66.
Good guys! Let's see I need help because I have done a thousand tests and I can't find what I need, I need 349500 km, it currently has 208048 km, I tried the changes with Digiprog, Smok, Nyo, Carprog .. all without success, can someone give me a hand? Thanks in advance !!
When someone takes the time to help you, say thank you, it's easy!
Here you go, try and report.
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
Showing 567800 km
[COLOR=rgba(0, 0, 0, 0.54)]
[/COLOR]
[/COLOR]
but this is also not right. I think you used nyo for it?? i had the same milage with using that prog.
mileage is 568517,
Hope someone can help me out
Read as 93c66 and use nyo or licznik 48 calculator.
vibe64 (16th April, 2021)
It can be done,
hello
i have already have the same probleme by dump
you can do by obd!!!
regard
