You can try this one,
Hi does any one have a clean dump for the discovery 93c56 dash, i belive i messed mine up by reading the chip wrong then it filled with ff somehow, so i can not get the orginal read from the chip
i need it to read 172516 miles if possible,
i have attached what i thought was the original dump
but i dont think i read it correctly as i have rewriten the file to the chip but the milage stays blank on the dash any advice will be great thanks
If i helped you with your problem, please press the Thanks button.
Ask your questions in the forum, no response on private messages.
jpsl (11th April, 2021)
thanks but it reads 107136 miles instead of 172516 think its swapped milage reading for km or vice versa
ive tried to change the km many times but it seems to write what it wants or random changes in upa or my script is buggered in upa as its always wrong
what do you use to edit the milage in the dump, and thanks for your help
oh its a uk disco if it makes a diffrence by the way
not sure what i am doing wrong if i read your file in carprog online i get 172384 miles but when i write to chip and load clocks i get 107136 miles, am i writing to the chip wrong or is it a setting in upa , what do you think
172384km = 107136miles
When someone takes the time to help you, say thank you, it's easy!
sorry its meant to be 172516 miles not km sorry my bad i should of been clearer is it possible to change it to 172516 miles please and again sorry
Try this one
jpsl (14th April, 2021)
Ok thanks will resolder and try ASAP and let you know thanks again for your help
Thanks it’s close it’s 10 miles out so still flashing but I think I have to write to both the clocks and the bcm,
do you think if I write on both it will sync and stop flashing or is there a software apart from nanocom that can sync them together?
You need to do BCM!!
jpsl (15th April, 2021)
Hi Yeap thanks, do I do the same small chip or is it the big square one in bcm as not sure which one to do ? Thanks
Motorola processor MC68HC11
Hi thanks mine different I think as mine says
xc528647cfn4
oh3or
kzqqqz0129
not sure why but here I go wish me luck
Il report how I got in a bit thanks again
