Results 1 to 5 of 5
    Sep 2019
    Default anyone able to help med with immo off with no dtc dash lights? Octavia ec17c64
    the car is a nightmare and i cant get my head around ths one.ecu cluster engine from donor car, keys from the original. immo is blocking and no SKC codes.This is a track car so need help with immo off so i can code the other units. Ktag is used to read full and epr
    Thanks guys
    Sep 2019
    sorry the file didnt get attached
    Sep 2009
    Hi. more vehicle and ECU data would be helpfully
    I do not have an immo-off solution for this ECU. You can try to tech-in a virgin key/transponder with this PIN: 10648.
    Sep 2016
    south africa
    No immo off
    Sent from my SM-A515F using Tapatalk
    Sep 2016
    south africa
    Sorry wrong threat
