Need Launch Control in my map. ME 7.1.1. Passat 2.8 v6
    Nov 2020
    Default Need Launch Control in my map. ME 7.1.1. Passat 2.8 v6
    I need Launch Control for my map. There is Pop & Bangs on the map right now and I don't want to change it so I would like to ask for a solution for my map. I want the LC to be set to 4300rpm.
    Information about the car:
    VW Passat 2.8 v6 4motion
    ECU: ME7.1.1
    Ecu id: 3B0907551CH
    Map attached
    Thank you in advance
    Nov 2020
    Refresh.
    Nov 2020
    Refresh
    Jun 2013
    EU
    The more you spam the less you will receive. And if i am not mistaken you are posting now for LC add a file someone ( Baddog84
    ) made for you with pop and bangs and sent you password protected for a reason, now is wide open.
    Dec 2019
    Default Passat launch
    Check this.Pass pm
  6. The Following User Says Thank You to gpepes2012 For This Useful Post:
    Marco141 (17th April, 2021)
    Jun 2013
    EU
    Quote Originally Posted by gpepes2012 View Post
    Check this.Pass pm
    Well done, in 5 minutes your file wide open asking for stage 1 on top of the popbangs baddog made for him (password protected) and on top of your LC also password protected.
    You guys really read the thread before posting or simply discovered a script and your ass rushes to try it on someone else's car?
