Results 1 to 9 of 9
    Apr 2020
    Default BMW e53 M57N Stage 1 request ?
    Hey, can somebody help to get stage 1 ?
    HW 0281011414
    SW 1037361878
    Upg. SW 07797399
    Klaudas1331's Avatar
    Dec 2020
    Lithuania, Kaunas
    File is already modified and has no read tag on it
    If my post was helpful, don't forget to press thanks!
    Apr 2020
    I thing this tuning is bad, too high rail pressure and have problems, can somebody share good stage 1 to confirm my suspicions ?
    Sep 2012
    Rail pressure maps are untouched. Duration maps decalibrated by 8% and NM to IQ maps also by 8%, Turbo Maps also by 8%
    You can try this
    Give rep and thanks
  5. The Following User Says Thank You to pericadex For This Useful Post:
    elvis898 (14th April, 2021)
    Apr 2020
    Is it possible to remve rev limiter ?
    May 2017
    Sure its possible to "remove" but you dont need to do such bullshit. Absolutly nonsens and just shows you dont get knowledge about diesels.
    Apr 2020
    Quote Originally Posted by Lambda1 View Post
    So if i have this engine in other car and ecu don't have speed signal, when driving it is going to 3000 rpm max then that's nonsense ?
    May 2017
    Nothing to do with rev limiter... its because of vss so yes nonsens.
  10. The Following User Says Thank You to Lambda1 For This Useful Post:
    elvis898 (15th April, 2021)
  11. #9
    Apr 2020
    Since the ECU does not see the speed of the vehicle, should this option be turned off instead of the speed limiter?
    Can you make this mod with stage1 ? Off course not for free.
