Results 1 to 15 of 18
    Apr 2021
    Default Best tool cas4 reading on bench
    Hi, need to do a bmw x3 2012 with cas4 module. Now i know by obd it is a risky job.
    To do it with less risk wanna do it on bench. I got the vvdi prog, but still risky bcs need to remove components. Does anyone know a tool that read on bench with no components te remove. Thanks
    Verzonden vanaf mijn iPhone met Tapatalk
    Dec 2020
    Quote Originally Posted by sisanovic1 View Post
    Hexprog or Hextag from Microtronik
    If it's AKL you also need Ecu ISN
  3. The Following User Says Thank You to Antonio266 For This Useful Post:
    sisanovic1 (14th April, 2021)
    Nov 2018
    Quote Originally Posted by Antonio266 View Post
    Only for cas4+, cas4 holds the isn in the cas
    Sent from my SM-N960U using Tapatalk
  5. The Following User Says Thank You to milehighlockdoc For This Useful Post:
  6. #4
    Mar 2018
    UK
    Hextag + Tango
    If is CAS4+ you will need ISN or working key
    Feb 2018
    Glasgow area
    ACDP is great for CAS4 in my experience.
  8. #6
    Mar 2018
    https://youtu.be/z-zpXX-Z9t0
    https://youtu.be/vtGukkyFojA
  9. The Following User Says Thank You to musti418 For This Useful Post:
    sisanovic1 (15th April, 2021)
  10. #7
    Apr 2021
    Thanks guys will look into it
  11. #8
    Apr 2021
    How about this one? Anyone got experience with this cable for the vvdi prog
  12. #9
    Mar 2018
    Hello, I did not buy this apparatus, but there is no need, you do not need to remove any capacitor in the vvdi prog connection diagram.
  13. The Following User Says Thank You to musti418 For This Useful Post:
  14. #10
    Apr 2021
    Hi musti, in the vvdi prog you can find 2 diagrams (5m48h) where you dont have to remove anything. Is this always? I dont have done any cas4 before.
  15. #11
    tepSIJA's Avatar
    Dec 2015
    OTP
    they say u dont need to remove any anything but reality is different ...
    I also advice you to buy HEXTAG/HEXPROG for reading CAS4 modul from.
    Tempus Omnia Revelat
  16. The Following User Says Thank You to tepSIJA For This Useful Post:
    musti418 (16th April, 2021)
  17. #12
    p1et's Avatar
    Oct 2013
    Just read vvdi prog manual. It say if can't crack MCU, then need to remove 1 resistor. So it does not always work without removing. When I do such work, I always remove that resistor before trying.
  18. The Following 4 Users Say Thank You to p1et For This Useful Post:
    andrym3 (16th April, 2021), musti418 (16th April, 2021), stoyanov (16th April, 2021), triak88 (16th April, 2021)
  19. #13
    ray-ray's Avatar
    Remember your voltage must be over 13volt to get the “Cas” to wake up. So your power source is best tool to get to read mode.
  20. The Following User Says Thank You to ray-ray For This Useful Post:
    stoyanov (18th April, 2021)
  21. #14
    Oct 2019
    Never had problems with 12v 2a
  22. #15
    castin's Avatar
    Oct 2015
    Cas4 buy for test - vvdi2 read on table, downgrade - all ok. Before use vvdi2 im read mcu and save flash and eeprom. Im load back saved file using vvdi prog, UPA-S - all OK. After load org file, vvdi2 again downgrade cas w/o problem.
