Results 1 to 7 of 7
Thread: build code
    Default build code
    hi can i find my build code thru my vin? if so how will i do it ?? thanks in advance
    Sep 2009
    Ireland
    Make & Model?
    Ronan
    Quote Originally Posted by sherl645 View Post
    Make & Model?
    Ronan
    pug 307 02 2.0hdi glx
    Sep 2009
    Ireland
    It's on the sticker that shoes that tire pressures and paint code. On the 307 I think it's on one of the pillars round the drivers door. I don't know of any way to calculate form VIN.
    Why do you need it?
    Ronan
    Dec 2009
    it says the build code on sagaii, post ur vin or reg on here if you dont have access to it and ill post it back
    Why do you need it?
    Ronan
    need it for pplannet to reset tne additive tank its on the door pillow but jus wanted to check.that it was right.just that its not picking additive ecu up as been there.just thought it might not be right.
    Nov 2009
    Ireland
    Maybe change the build code and see if the addtive ecu appears....the build code can be got from on-line servicebox when the vin code is entered, normally in the "vehicle characteristics" menu.....
    Ron.
