Immo off is applied to ECU, not to dash.
It's very easy to swap the dash in this case and readapt the existing keys, but login should be accepted.
i read now the mesuring data in 17-instrument:
in chanel
22 is 0 1 0 0
23 is 0 0 0 6
24 is 9 0 0 9
Can you change data in the new dashboard with this in old, only immo and this
According to your data:
- 22 (2 field) - ECU answers - OK.
- 23 (1 and 3 fields), there is no transponder (chip) in your key or it's of wrong type.
- 23 (4 field) - im*o system is in good condition.
- 24 (1 field) - Instrument cluster should be powered with ignition on untill digit 9 countdown to 0.
- 24 (4 field) - Transponder recognition is bad.
First of all check your key. You have to use your own keys or virgin transponders only and not from any other car, because there chips (Megamos 48) are locked.
danielif (29th October, 2020)
Hello !
I did it wiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii its workingI copy al adresses from 0 to 176 hier is the immo in old tacho witch working, to may new tacho in the same adresses, and now may tacho with board computer working
Its simpl
Thanks to alll
