Results 1 to 5 of 5
    Jan 2021
    Default Correct adjustment? My first EEPROM
    Hi guys,
    It's my first edit, i've bought an old second-hand Citroen C1 dashboard with an 93C56. The original km was 151194km. For testing and learning purposes i've adjusted it to 98765km.
    Is there someone who can verify i've done the right adjustment? So i can learn from you guys.
    I'm willing to learn and not to just simply upload an dump and ask for adjustment..
    Also is there a way to power up the dashboard to know if it works? I've tried all the pins but don't seem to succeed..
    Thanks for any help!
    Oct 2018
    98770.km......
  3. The Following User Says Thank You to liri For This Useful Post:
    hendymen (15th April, 2021)
    Jan 2021
    Mileage is fine. Here you have pinout:
    https://www.digital-kaos.co.uk/forum...itroen-C1-dash
  5. The Following User Says Thank You to MasterSc For This Useful Post:
  6. #4
    Jan 2021
    Thanks alot!
    from the pinout i should apply positive current to the two red marked pins and negative to the black ones. However, the blue and green pin, do i need to shorten them together?
    Thanks!
    Jan 2021
    No, they are for speed and fuel level gauge.
  8. The Following User Says Thank You to MasterSc For This Useful Post:
