Results 1 to 12 of 12
    shtyrya2's Avatar
    Jun 2012
    Argentina
    Default VW UP ME17.5.24 0261S10004 please immo off
    Hello DK! Can someone please make a immo off of this ecu? Its a VW UP, original ecu mcu was in short circuit.
    ME17.5.24 0261S10004 flash attached
    Thanks!
    Jun 2013
    EU
    Quote Originally Posted by shtyrya2 View Post
    Thanks!
    Here mate, give this one a try
  3. The Following 2 Users Say Thank You to morgano For This Useful Post:
    IMM0killer (20th September, 2022), shtyrya2 (16th April, 2021)
    shtyrya2's Avatar
    Jun 2012
    Argentina
    Thank you, will test.
    shtyrya2's Avatar
    Jun 2012
    Argentina
    Hey morgano, working perfect, only EPC light on. Thank you!
  6. The Following User Says Thank You to shtyrya2 For This Useful Post:
    H2Deetoo (23rd April, 2021)
    Jan 2022
    How did you fix the EPC light?
  8. #6
    Mar 2022
    Hola tengo misma numeracion de ecu en vw up y me ayudaria mucho si me comparte el pass para descarga
    pass please
  9. #7
    Nov 2018
    Hello, I have the same control unit number in the Seat MII and it would help me a lot if you could provide me with the password to download. Thank you.
  10. #8
    Nov 2018
  11. #9
    richard27's Avatar
    Aug 2011
    They will help you upload your files.
    ​information sharing
  12. #10
    Nov 2018
    Default Bosch ME 17.5.24 ImmoOff
    Hello..Can someone please make a immo off of this ecu? Its a Seat MII Bosch ME 17.5.24.
    Very Thank.
  13. #11
    richard27's Avatar
    Aug 2011
    Quote Originally Posted by wasja38 View Post
    Merhaba.. Birisi lütfen bu elektronik üniteden bir immo yapabilir mi? Bu bir Seat MII Bosch ME 17.5.24.
    Çok teşekkür ederim.
    merhaba, dosyalar pm'den gönderiliyor
  14. The Following User Says Thank You to richard27 For This Useful Post:
    wasja38 (1st April, 2024)
  15. #12
    Nov 2018
    Hello..Thank you richard27..I tested and report..May I ask which program you used?Is the checksum also adjusted?
