Results 1 to 10 of 10
    skens's Avatar
    Zagreb,Croatia
    Default RENAULT TWINGO 1.2 16V sim32_S120201108A
    hi
    i need immo off 95160 !
    i try solution for clio3 but not ok!!
    regards
    tnx
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
    skens's Avatar
    Zagreb,Croatia
    hi
    i read 64F7055 flash !
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
    Dec 2018
    Default Twingo
    Hi Frend. You immo off. Test and report. Give thenks+reputation and pass prive
  4. The Following User Says Thank You to elektronik325 For This Useful Post:
    skens (16th April, 2021)
    skens's Avatar
    Zagreb,Croatia
    hi
    this is solution immodecoding 3.2! not ok
    please not test solution!!!
    refards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
    belgrade,serbia
  7. The Following User Says Thank You to vladanr For This Useful Post:
    skens (17th April, 2021)
  8. #6
    skens's Avatar
    Zagreb,Croatia
    hi
    I did and I tried that solution, it doesn't work
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  9. #7
    Dec 2018
    Default Twingo
    Today I was watching your file and I can see that there have already been some changes. You have my file here that burns 100% and additional info. The password is the same. Check and report, regards
  10. The Following User Says Thank You to elektronik325 For This Useful Post:
    skens (19th April, 2021)
  11. #8
    skens's Avatar
    Zagreb,Croatia
    hi
    not ok!
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  12. #9
    Dec 2018
    Quote Originally Posted by skens View Post
    hi
    not ok!
    regards
    This car start file 100%. There is some other problem with the car or ecu. Regards
  13. #10
    skens's Avatar
    Zagreb,Croatia
    hi
    no program is not good !!!
    fixed the key, turned on !!
    1 sw good as virgin, 2 sw the car runs restlessly and has no power
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
