Results 1 to 4 of 4
    Apr 2021
    Denmark
    Default VW Golf 7 MIB testbench
    I "try" to make a testbench for MIB2, i have dashboard, canbus, headunit/display, (harnes is from China), but a have problem, i need a ignition (15) but I don't know where to find/get it....
    Hope someone can help
    Dec 2017
    Send manuell or use Boardnetz ecu in bench Setup
    Apr 2021
    Denmark
    I hope to make a simple test bench with out only for test radio (and change it).....what do you meen with manuell ? ;-)
    salkapone's Avatar
    Oct 2013
    Manually means send can data for wake up,, another way is : need belonging can gateway, bcm dashboard and key(component protection issue) if you need adopt used mib to vehicle... If u just need for testing purpose doesn't require belonging parts, you can use from scrap yard.. If u wish already finished and profi bench setup, i have few in stock for sale
    Sent from my ELE-L29 using Tapatalk
    Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
