Results 1 to 7 of 7
    May 2010
    Default \Fiat 334 VP2 ECE NAV need Code
    Hi i need code \Fiat 334 VP2 ECE NAV
    The label is not
    Dump M29W256
    Apr 2010
    post label picture
    May 2010
    Hi, label damaged.
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by Hack01 View Post
    The label is not
    Dump M29W256
    Hi, label damaged.
    Hello,
    Not sure about the code but tried this code . . 1236
  5. The Following 2 Users Say Thank You to Albert G For This Useful Post:
    Hack01 (20th April, 2021), masterskay62 (20th April, 2021)
  6. #5
    May 2010
    Thank you, I will try and write tomorrow.
  7. #6
    May 2010
    I apologize for the late answer, I only started the communication between the radio and BCM yesterday. Result: code 1236 incorrect
  8. #7
    Raimax's Avatar
    Nov 2013
    LT
    Yes because not that barcode
    If you don't like it * close your eyes
    --- Geros dienos ! ---
