corsaa d uses pcf 7941 remote intergraded suitable only for this model,if customers key can not program again maybe it is a clone
https://www.car-keys-online.com/oem-...2007-2012.html
edit
Corsa D (2007 - 2012)
had a cosra d in 2014 customer asked for key , l only had insignia and astra H keys in anyway , her key was delphi 13387369 , but l did try and code a chip , l got keycode with i/o terminal , xtool kept showing failed to code key and even if erased keys it would say that even with original key failed but would code that back ok ? even autel do the same thing say failed vvdi doesnt list universal key for this one, is there something odd about these ?
edit
thank you, yea l ordered somes keys , her key did program back even tho xtool/autel said it failed ? fingers crossed the right key will work ok , just wondered if this delphi system was abit strange
simple car,with the correct remote 1 minute job
smirnoff_rules (20th April, 2021)
yea thanks, just strange how diag tools were acting, since xtool update it crashes all the time tool , crap tool
rokibar (21st April, 2021), smirnoff_rules (20th April, 2021)
Try to find genuine second hand and renew
they looks the same like Astra but when you open the batery cover and take out the battery they have QR code - Astra and Zafira they don't have
If you set carbon chip to crypto mode (0E instead of 06) then it will code but the central locking won't work. Key in barrel will only operate drivers door.
smirnoff_rules (22nd April, 2021)
programmed ok with autel and the right key , thanks all
Whats such a problem with this key? Corsa D and Astra H use absolutely the same key, only difference is in precoding which you change with fvdi tag or vvdo mini keytool in transponer generarion. Just choose Corsa D remote key while precoding. It works fine, did the job tens of times without anyone complaining. You could use superchip precoded as remote key as well..
They are 100% different.Whats such a problem with this key? Corsa D and Astra H use absolutely the same key, only difference is in precoding which you change with fvdi tag or vvdo mini keytool in transponer generarion.
Valeo vs Delphi. Different layout and even if you change precoding, it will learn and start the car but remote isn't working.
smirnoff_rules (13th May, 2021)
Original keys...
Astra-H : with white glue
Corsa-D : with blue glue
Remote re-new, and use again...
Polak, wegier dwa bratanki i do szabli i do szklanki
