    Jan 2018
    Default VW Transporter 1.9 tdi remap file 2006 correct or not?
    Hi all can some one check for me please if my map file is correct.After remap my power increace only a bit.I replace my turbo to biger one from audi 130 bhp after that one of forum members done for me remap but I think it doesn't work.Might be issues not in map but in mechanical side.Thanks
    Aug 2020
    Quote Originally Posted by Bitlas View Post
    If you cant feel much of a difference after flashing this file something is wrong with car 1.65bar boost request and 70mg
    3bar map sensor is calibrated and the n75 values are from a pd130 engine
    all maps have been covered boost wise so nothing holding your boost back this file should make around 175hp and 440nm
    looking at the file everything seems ok all axis changed
    something deffo wrong with car if you dont notice a change or not much of a change
    alonedark's Avatar
    Feb 2017
    the turbo run a few kilometres
    Aug 2020
    Quote Originally Posted by alonedark View Post
    Here we go again 1.65bar is perfectly safe on pd130 turbo there garrets i run mine at 1.7bar for 2 years all fine
    alonedark's Avatar
    Feb 2017
    si sobre todo despues de las 4000 rpm is very safe
    Jan 2018
    Hi all attachment was removed due to file was corupted and not suitible for use.I was advised that after long use it can damage engine.Guys if you download it do not use.Thanks
