Hello
Inside your radio must be flash memory with signature 29F400,i m pretty sure must be 2 pieces of that memory,one is on one side and one is on another side (if he have two pieces)
You need to read it and post dump to get a code.
Hello everyone! I found this forum in desperate search for codes for my Lancia Lybra radio.
I was solving a problem with the car cigarette lighter and disconnected the radio, before thinking if the previous owner gave me the radio codes... And he did not.
Me being the noob I am, tried to talk with the previous owner that had no idea, so I looked for several different eBay sellers with no luck, all the codes were wrong (and interestingly enough, different...) I also went to a few facebook groups and met a few people that tried to help me, with no luck. All nice people, but couldn't help so they all gave my a refund.
Googling for a solution I found this forum, and started reading some posts that talked about the way you convert the serials into the radio code, even some 2010 posts for the specific radio model, interesting stuff, but I could not find enough information for my radio, either that or I'm too much of an idiot to figure it out. (Also one of the posts with exactly my radio, from one facebook sellers that tried to help me earlier, so this is not a duplicate)
So this is me asking for your help, as without a code I will be in a 5 hour silent drive tomorrow.
There are two codes (NAVI and ICS), but according to the owner manual, only the ICS is needed to activate the radio, I'm not sure though.
Car: Lancia Lybra
BECKER:
Model No.: BE2580
Serial No.: Y5052244
Siemens
MLFB: 5WK 78119
Serial No.: LA1190000818/03
Images below
Thank you for your time!
Hello
Zaduno (3rd May, 2021)
I've been looking online and the tools I found are even more expensive than going to the dealership. Do you have any suggestions in what to get?
Also, I've found posts here that claimed it was possible to get the codes from serial, for the same radio, using Martech (that again, is more expensive than going to the dealership)
Best Regards
So after getting a few different codes from different people, that did not work, I disassembled the radio and I don't know which of the 29F400 to read (There are two, one on the top, and one on the bottom), I took some photos so that maybe anyone can help me find out.
Thank you
Hello again!
I managed to get the dump (hopefully this is the correct dump). I'd be grateful if someone could help me get the codes from dump.
Thank you!!
Edit: I forgot to mention that was the EPROM on the top.
cheero (1st June, 2022)
Crasftsman (31st May, 2022)
