Results 1 to 11 of 11
    Mar 2016
    Kingston Jamaica
    Default 2015 Subaru Impreza without Immo but No Start
    Hello,
    I have a a 2015 Subaru Impreza, Chassis #GP2-033395 without Immobilizer yet there is an Immo Light Flashing in the Cluster and the cannot start.
    There is No Immo Ring and No Connector for it either. Immo Ligjt comes on when the key is inserted. Car will Crank till the light comes on then cranking stops.
    Engine ECU has "DY" Label with 93C56 Eeprom, BIU Body Control has "GA" Label with 24C01 Eeprom and Cluster has 93C76 Eeprom.
    Took files from another Similar car but boxes had different labels and BUI had 24C02.
    Tried to align by OBD with Launch, G-Scan, AVDI Diagnostic Tools without success. Dealer quit on this car.
    Looking forward to your reply.
    Br, Daymond
    Apr 2016
    post BIU dump
    Mar 2016
    Kingston Jamaica
    Hello,
    Thank you. I will do so tomorrow.
    Br, Daymond
    Mar 2016
    Kingston Jamaica
    Default 24C02 BIU File attached
    Hello,
    Had difficulty attaching file and somehow did it as a RAR File. I hope you can open it.
    Br, Daymond
    KriptoKey's Avatar
    Feb 2012
    Actually your file does not have keys, but can you tell us what fault code you have in motor ecu?
    Mar 2016
    Kingston Jamaica
    Hello,
    Thank you for your attention. I will scan the car and send ECU error CODES tomorrow. This car has no immo yet cluster immo led Illuminates and cranking stops.
    Local techs claim to see this often yet their fixes do not work on this car.
    I have BIU, ECU and Cluster Dump for what it's worth.
    Br, Daymond
    achaccha's Avatar
    Nov 2010
    I will analyze your case friend
    But I only see in your post the dump of the integrated unit. Please post the file of dashboard, integrated unit or BCM and motor ecu.
    I will analyze and give you a solution soon.
    regards
    Mar 2016
    Kingston Jamaica
    Hello,
    Engine Error code is P1572 Immo Circuit Failure (Except Antenna Circuit) and Integrated Unit Module is B1402 Immobilizer Key Coillation "Not Good".
    I will post All files, Cluster, Engine ECU and BIU files tomorrow.
    Br, Daymond
    Mar 2016
    Kingston Jamaica
    Hello,
    Thank you in advance for your help. Attached is the BIU, Engine and Cluster Files and I anxiously look forward to tour reply.
    Br, Daymond
    Mar 2016
    Kingston Jamaica
    Hello,
    Attached are BIU, ENGINE and Cluster Files and I anxiously look forward to your reply
    Br, Daymond
  11. #11
    Mar 2016
    Kingston Jamaica
    Hello,
    I am anxiously looking forward to your reply. I posted all files so please take some time out of your busy day.
    Car is with me for many months now as the customer is counting on me.
    Thank you.
    Br, Daymond
