" load nk.bin into my Samsung arm9."
You need start Diagun soft in another device?
Or restore Diagun?
Or restore Diagun?
Dump Diagun .
http://files.mail.ru/T2CT8R
mmm323 (7th March, 2015)
Nk.bin Diagun.
I buy Micro2440(Mini2440) with display 7".Downloads - FriendlyARM
I made NK.bin 2440 with Platform Builder .
First Tool to make complete image backup (clone) of my Diagun
Second I need clone copy of good working Diagun with activesync to reload into mine. If it doesn't work I can always restore my diagun from my image.
Thanx
I do not recommended to touch wince5 Diagun!!!
Loader Diagun format all, NK.bin more 30 M-no stantart wince
and anather loader no work with him .
Wince5 Diagun have hidden registry and windows.
Restore only with programmer damp!
Thanx Sergej, can you recommend a WinCe Device with bluetooth that will run NK.bin, as a replacement to Diagun handheld.
I got an orginale diagun to work with activesync even with Win7 and WDM 6.0 no problem easy to connect. Problem is with Chiness clones they have networking and activesync disabled. Basically anything to do with USB communication and a PC is disabled. I have compared files and registry entries and even if you match everything, there is a portion of the program that is in the ROM and Hive registry that you will never figure out.
Replacement of the ROM chip is the only way to make a chiness clone an orginale Chiness clone LOL. (Who's copying Who).
Your Diagun have problem in registry with Dial connection.
Open Start-Setting- Control Panel,Network and Dial,delete connection.
If not connection-Make New connection "Dial up connection",
than delete it.Reset.
Test USB.
I have tried that ...thank you
What I have noticed is that tapi.dll is missing in the WinCe windows directory. I can not make copy of file because it's being used in ROM in the emulator or good Diagun. Please can you post copy of file...Thanx
You can copy dll from emulator when connect ActiveSync.
@sergej
Hi m8
I tried to use the Diagun smartbox using my laptop bluetooth.
And I've got this error
Please tell me if it is necessary to use just external bluetooth with BlueSoleil?
Good luck
You can test without Bluesoleil -post72 http://www.digital-kaos.co.uk/forums...ml#post1310218
Bluesoleil =china software for china BT.
