Page 12 of 44 FirstFirst ... 2789101112131415161722 ... LastLast
Results 166 to 180 of 649
Thread: diagun help
  1. #166
    Oct 2008
    On Earth
    Quote Originally Posted by sergej View Post
    You can test without Bluesoleil -post72 http://www.digital-kaos.co.uk/forums...ml#post1310218
    Bluesoleil =china software for china BT.
    Well my dear friend
    You don't folow me I suppose
    I use my laptop bluetooth
    I can paired the smatbox
    I can connect to the smartbox but when I choose the car to connect I had that error, after the softwear recognized my smartbox and showed me the S/N
    The bluetooth it recognize my smartbox
    What I asked you is if it is a difference between internal bluettoth laptop and external bluetooth as the one you showed me.
    Good luck
  2. #167
    DK Veteran sergej's Avatar
    Latvia,Riga
    Software Diagun work with Bluetooth modul Diagun .
    He have china software.
    When I made emulator I test with unsolder modul BT Diagun .
    He work good .
    Another modul BT modul work only with Bluesoleil.
    You can test winxp driver or Widcomm software.
    Good luck
  3. #168
    Oct 2008
    On Earth
    He work good .
    Good luck
    Hi srgej
    With Bluesoleil and external bluetooth
    Works and no communication error
    Now I will try again with laptop internal bluetooth but not in a car
    Tommorrow I will do it again
    I wiil informe you then
    Good luck
  4. #169
    Oct 2008
    On Earth
    It dosen't work with my laptop internal bluetooth
    With external Blusoleil blueetooth works
    Thanks sergej
    Good luck
  5. #170
    Toronto, Canada
    WOW Success Finally
    This is what is need to be done. First of all download this File from Sergej TAPI.dll.
    Load it onto Memory card
    Copy it into \ResidentFlash directory
    Open Registry HKEY_LOCAL_MACHINE ... Drivers...Builtin ... Tapi
    edit dll To include path "\ResidentFlash\TAPI.dll"
    ReBoot
    Thank You Sergej
  6. #171
    Oct 2008
    On Earth
    Quote Originally Posted by powertech View Post
    WOW Success Finally
    ReBoot
    Thank You Sergej
    Open registry in your computer I suppose.
    Can you explain a littel bit, please
    @ sergej
    I wasn't be able to change the bluetooth com prts in my laptop but I took a friend of mine his laptop Windows 7 64bit and I coud be able in his laptop to make it works
    Now I'm intristing in this making use it by USB
    Please explain a littel bit the procedure. Thanks
    Good luck
  7. #172
    Latvia,Riga
    If N BT com-port>9 you can delete hidden com port(winxp):
    1.Start-Run , copy this text " cmd ",paste in windows -OK.
    2.In you PC will open DOS windows.
    Copy this text " Set devmgr_show_nonpresent_devices=1 ",
    paste in DOS windows. Enter.
    3.Copy this text " Devmgmt.msc " , paste in DOS windows. Enter.
    4.In you PC will open Device Manedger .
    View -> Show hidden devices. -Enter.
    5.Open Port(Com and Lpt)
    You will see hidden port.Delete their.
    6.Reinstall BlueSoleil.
  8. #173
    Oct 2008
    On Earth
    Now it's working thanks to sergej
    Good luck
  9. #174
    Member aygo's Avatar
    Maybe someone have resolved with emulator diagun update fail ??
    Some diag tools + 2kg hammer
  10. #175
    Latvia,Riga
    You have problem with new update?
    See size file "LICENSE.DAT" in GAG\VEHICLES\version .
    If size=0 install new version with "X431 Series UPDATE ",
    or copy GAG from Diagun.
  11. #176
    I have updates files but i dont have the diagun i have only bluetooth smartbox.
    I dont know how put updates without fail.
    I have downloaded x431 series update but no luck .. maybe i dont know how must be used...
    License file in both gag folder old and new is 1KB
    If you want to ceck with teamviewer.....
    Tnx
  12. #177
    Toronto, Canada
    When I hookup to the vehicle I get errors or ???? in the data values. I have made sure that COM ports are less than 9, deleted all extra ones then install IVT Bluesoleil.
    have tried version
    IVT Bluesoleil 2.7 (2.6.0.8 Release 070517)
    IVT BlueSoleil v6.4.249.0
    IVT BlueSoleil 8.0.370.0
    all with the same results, in the emulator the ports assign to the bluetooth device are not available. Does matter if it is craddled or activesync.
    When I install with the software that came with the bluetooth receiver very thing seems to works and ports are assignable in the elmulator but doesn't work on the car.
    Going to try with a different bluetooth receiver soon.
    Would you have the right version of IVT blue that u can post or should I stay with version 6?
    What should the comport setting be?(speed parity etc)?
    Thank Sergej
  13. #178
    Latvia,Riga
    1.Go in http://176.9.136.155/?lang=en
    register and download free new Display and Demo with
    your S/N. No unpack zip file!
    2.install Display and Demo with "X431 Series UPDATE http://just431.com/files/X431_SERIES_UPDATE_75.zip
    3.Test Demo (your smartbox will be updated).
  14. #179
    I have a diagun software to share but not so new,if you need,pm me with your serial plz
  15. #180
    Oct 2008
    On Earth
    Guys
    Each smartbox has it's own serial number
    The softwear must be for this serial, other wise it will never works.
    Good luck
