Page 14 of 44 FirstFirst ... 491011121314151617181924 ... LastLast
Results 196 to 210 of 649
Thread: diagun help
  1. #196
    DK Veteran sergej's Avatar
    Latvia,Riga
    You can manual write N com port " comN " .
    If OK you can modifu icon "800X480 Extra Eng.cmd"
    right mouse in icon and write "/u1 comN /
    "Emulator\DeviceEmulator.exe" NK.bin /memsize 256 /video 480x480x16 /u1 com5 /nosecurityprompt /sharedfolder ""
  2. #197
    Toronto, Canada
    Steps to install
    Create directory for Diagun with Bluetooth Emulator
    Copy GAG folder software from SD card for your Diagun Transmitter - Software and Transmitter must match
    Install Giveio.sys
    Install IVT BlueSoleil Works with all 2.7 (2.6.0.8 Release 070517) and up
    Install BlueTooth Receiver - pair and connect...password 1234
    Note Connected Com Port Number #
    If Com Port is greater 9 - delete hidden ports
    Cmd
    Set devmgr_show_nonpresent_devices=1
    Devmgmt.msc
    End
    Set Com setting to 19200, 8, None, 1, None
    Edit Cmd Line "Emulator\DeviceEmulator.exe" NK.bin /memsize 256 /video 800x460x16 /u1 com# /nosecurityprompt /sharedfolder ""
    Turnoff any unneeded Bluetooth services ie audio etc.
    Creat shortcuts
    Were I went wrong was to install Receiver before IVT Soleil. Receiver software was getting in the way of how IVT Soleil operates.
    Therefore commands seemed to work but not completely.
    Thank you again Serjeg for all your help - your are a master
  3. #198
    Latvia,Riga
    "Set Com setting to 115200,"
    This speed for boot wince5.
    For Diagun and emulator speed com-port=19 200 !!!
  4. #199
    Toronto, Canada
    Ok all connected, but after 30 sec of veiwing car data it freezes up. Have tried different Bluetooth recievers same results. Maybe port speed setting or memory buffers.
    Any ideas
  5. #200
    Latvia,Riga
    You use notebook or big PC?
    In notebook have energy savings .Set " constantly".
  6. #201
    Latvia,Riga
    Software Diagun work with Bluetooth modul Diagun.He have 1M memory with china
    software.
    I test emulator with unsolder modul BT Diagun .
    He work good without Bluesoleil.
    Another modul BT modul work only with Bluesoleil.
    You can test cable connect -see post 68,189.
    You can test HC-05 -see post 67.
  7. #202
    Default Diagun reset function
    I think many of Diagun user don;t know Diagun has this function
    http://x431diagun.blog.com/2012/02/15/x431-diagun-pda-reset-function/
    Just want to share when I saw this blog,but hope this won't break DK's rule
  8. #203
    Latvia,Riga
    New version Demo V14.10 and high show S/N.
  9. #204
    Toronto, Canada
    Just did a comparison of an OE diagun unit and a chiness clone. The clone has alot small problems accessing the vehicle, freezing and error messages.
    I think Sergej your need to create a Bin file from a OE unit. This way we can start from a good operating program, and we can tweak it from there.
    Just an observation
    Frank
  10. #205
    Member aygo's Avatar
    Finnaly received HC05 module for connect to diagun connector but i have some problems for connect and send AT commands with hyperterminal ...
    Any chance to get some help or exist better software for talk with rs232 port or wich is the setting to do this ...
    I have found also different software but on every commands the module hangs and wont connect ...for every command must disconnect the power .....i think this is not the right way !!
    Working on it .....
    Some diag tools + 2kg hammer
  11. #206
    Latvia,Riga
    I don't test HC-05.
    But my friend connect HC-05 with ARM11 device(picture him device
    http://4pna.com/showpost.php?p=103890&postcount=947 ) and working with Diagun software.I ask him.
    Also see http://iteadstudio.com/produce/more-...e-masterslave/
    http://robocraft.ru/blog/electronics/587.html
    http://habrahabr.ru/post/125214/
  12. #207
    Like i say before on the first command AT to com i have response on second hangs and no response ... i must disconnect the power to module then work again ... i think connection problems
    So first command to restore to default the module :
    AT+ORGL
    1-Equipment ID = 0
    2-Search code:0x009e8b33
    3-Working role =Slave Mode
    4-Connection mode =Specific Bluetooth module
    5-RS232 configuration=Baud Rate?38400bits/s or 9600bits/s; Stop
    Bit=1-Parity-None None
    6-Pair code=?1234?
    7-Device name "HHW-SPP-1800-2"
    Next command to set from slave to master mode :
    AT+ROLE=1\r\n
    now cecked the response with
    AT+ROLE?
    response ROLE=1 OK now the module is in master mode
    Now the command for set the speed :
    AT+UART=19200,1,0
    Next steps later ... must go to work
  13. #208
    Latvia,Riga
    Test
    "3. PIO11, control the module working mode, High=AT commands receiving mode(Commands response mode), Low
    or NC= Bluetooth module normally working. "
  14. #209
    Latvia,Riga
    "now cecked the response with AT+ROLE? "
    You have HC-05 or HC-06? Byron's Blog: One board... several firmwares
    Also r\n =Enter?
    My friend said
    1. Give in smartbox 12v,run Bluesoleil and see adress
    smartbox (example 0018,E4,1A3E8A)
    2.HC-05 in program mode,
    AT+ROLE=1 ,
    test AT+ROLE?
    3.See pin-code AT+PSWD?
    If no 1234 -set AT+PSWD=1234.
    4.AT+UART=19200,1,2
    Test AT+UART?
    5.AT+CMODE=0
    6.AT+BIND=0018,E4,1A3E8A(your smartbox adress)
    Test AT+BIND?
    Test terminal Termite: a simple RS232 terminal
  15. #210
    Quote Originally Posted by sergej View Post
    Test
    Also r\n =Enter?
    AT+ROLE=1 ,
    test AT+ROLE?
    4.AT+UART=19200,1,2
    Test AT+UART?
    5.AT+CMODE=0
    Test AT+BIND?
    Yes PIO11 to high for send AT commands.
    The module is the same of your picture on post 67
    My big problem is to talk with com port and the module ... i send one or two commands then i dont have answers for module ...
    Tnx for help .... very appreciated !!!
