Page 18 of 44 FirstFirst ... 8131415161718192021222328 ... LastLast
Results 256 to 270 of 649
Thread: diagun help
  1. #256
    Top Poster rafekj's Avatar
    Oct 2008
    far away
    have been there but can't add funds
    please press the little red THANKS tab
    if I helped u
  2. #257
    DK Veteran sergej's Avatar
    Latvia,Riga
    Buy update
  3. #258
    Oct 2008
    far away
    have done that as well....
    then i choose 1st on top of the list
    enter card details / comfirmed amount what they took from my account for security reasons
    but when tried to pay or add funds it says that it is not possibe to use this card.
    I have used this card for internet payement before
    if I helped u
  4. #259
    Oct 2008
    On Earth
    Quote Originally Posted by rafekj View Post
    You can use paypal it is the simpliest way
    Good luck
  5. #260
    Latvia,Riga
    You selekt Interkassa? Word Visa?
  6. #261
    Oct 2008
    far away
    have tried all of them NG.
    if paying via paypall what details i have to leave and what about fee?
    if I helped u
  7. #262
    Latvia,Riga
    I do not know. Ask mattydr67
  8. #263
    Oct 2008
    far away
    i did tried again step by step and it did work this time...
    and i was doing it exacly the same before but with negative result.
    anyway thank you very much for your support
    if I helped u
  9. #264
    Latvia,Riga
    Ok!I send message PayPal
  10. #265
    Latvia,Riga
    If your Diagun can't boot-the problem is poor quality flash memory K9F1G08.
    Try disabling all the battery for 24 hours. Then turn on without the battery hours .
    The only way to burn K9F1G08 -in programmer.
    Dump for programmer diagun_ok.zip ??????? ? ?????@Mail.Ru
  11. #266
    Latvia,Riga
    I set wince5 in my Mini2440 for 1 min with com port and USB.
    In Diagun bad loader and no standart wince5 file=NK.bin.
    If you want to try to establish a standard way, I can help you.
    Image Diagun NK.bin
    http://www.digital-kaos.co.uk/forums...ml#post1446728
  12. #267
    spain
    Cool !!!!!!!!!!!!!!!!!!!!!!!!!!
    hi my friend
    Are there any solution for this error ?
    cordially
  13. #268
    Latvia,Riga
    This error- bad conecting .
    Test with cable.
    Test another car.
  14. #269
    spain
    Quote Originally Posted by sergej View Post
    Test with cable.
    Test another car.
    thank you for your response
    I tested on another car but it's the same things
    The problem is that I mix but between two update
    I had an old and I bought a new update but I add the old directory car in the new update and this message came
  15. #270
    Oct 2008
    On Earth
    Quote Originally Posted by electroniquearts View Post
    Mate
    That update it is ( I suppose ) because you use the bluetooth.
    Try to use the cable
    As I said many times in this thread this error I had it when i used the emulator made by sergej with my laptop bluetooth.
    Or you can to paired again the smartbox with the PDA
    Report how it works with the cable and if it's working with your not upgraded softwears
    Good luck
