Page 24 of 44 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 649
Thread: diagun help
  1. #346
    Thank you, I dont know why I cannot do this with that update program I have downloaded it & reinstalled it several times the required test box always comes up blank as does the left box with no options to click on i.e. demo etc a message pops up (without selected update file please select update file) When I go to the source folder it cannot seem to find this update file. I dont know how to re size the image to post it on dk It looks the same as your image but without options to click on
  2. #347
    DK Veteran sergej's Avatar
    Latvia,Riga
    Unpack and copy this GAG in your microSD.
  3. #348
    Thanks I realized one of the problems I created was unpacking the zipped folder before using launch update that is why it could not find installation file at the designated source folder I . I managed to load demo 14_30 gag onto sd card but could not see how to test it! I also put the gag file you just sent onto sd. I am formatting sd before each gag file is installed but whatever I put on it my diagun cannot read. (message states check memory card) I was wondering if perhaps I have a driver fault because if I go into my control panel on diagun whatever I try to access (message cannot find 'CTLPNL' or one of its components)
    pops up on every item I try to enter
  4. #349
    Sorry the unit is messing with my head I just restarted it & everything works in control panel again but is still doesn't read memory card
  5. #350
    Latvia,Riga
    See My Device-Storage Card.If no: 1.You have standard microSD 1-2 G? 2.You format microSD ? 3.Test another microSD.
  6. #351
    I can only see resident flash with doc set default folders & nothing in them.
    Control panel storage manager storage properties part 00 part01
    sorry I dont know ce system to know what I am looking at
    If I look in my device it makes no difference to what I see whether the micro sd card is in or out so I am starting to think it has lost drivers to this or card reader inside diagun is faulty! are there items inside I can test in any way if that is the case?
  7. #352
    Latvia,Riga
    Test another new microSD-Kingston or Sandisk.
    No test old from mobil tel or microSDHC.
  8. #353
    Thanks I have been reading through threads that diagun may not be able to read sd card bigger than 2gb the smallest I could buy anywhere is 4gb I have tried everywhere possible again this evening to find smaller than 4gb but because of low demand for 1 or 2 gb nowhere stocks this. The 4gb is brand new & works ok on pc but not on diagun so maybe I will need to try a few other suppliers. Thanks for all your time I will let you know the outcome!
  9. #354
    Latvia,Riga
    In my Mini2440 I use 16G.
    In Diagun install old driver SDHC.
    1.Test-set name your microSDHC in SDHC.
    2.New driver 913 Sdhc Driver.cab. I test on Mini2440. I no know how this driver will work with Diagun.
    You can test this driver on your risk.
    Unpack.File 913_Sdhc_driver.cab copy in Resident Flash.Run 913_Sdhc_driver.cab-set Windows.
  10. #355
    Latvia,Riga
    Also you can connect SDHC with card reader via cable
    printer.In My device you will see Hard Disk.
  11. #356
    I managed to get 2gb micro sd card today, supplier informed me larger than that it changes to hc (high capacity) a file system structure which is completely different some old operating systems cannot recognize this at all!
    I have just put this in my diagun & I can now see storage card in my device & disappear when I remove it.
    So next I just need to load gag file & try it out
  12. #357
    The micro sd card seems to work fine now the only problem is I need to find a gag file that is compatible with my diagun serial number I have tried loading several different updates to my sd card but they all prompt please contact your local launch distributor when checking smart box I dont know if this is because I have wrong gag file or if it is a problem with smart box.
    If anyone knows of gag file that will work with my serial number I would be most grateful, it doesn't matter how old it is, it would just be nice to have my diagun working again!
  13. #358
    I finally found the correct software update for my diagun & it all seems to be working well now!
    Thank you so much for all your help Sergej it is very much appreciated
  14. #359
    DK Veteran NZBrakelathes's Avatar
    Aug 2010
    Zibo Shandong China
    Anyone know where I can safely find IGO8 maps for my Chinese GPS?
    Bit of topic huh?
    Nothing on DK and I cannot deal with viruses so any help be great!
  15. #360
    Aug 2010
    Zibo Shandong China
    Anyone know where I can buy a used master without the case etc? Or anyone need case and connectors for one?
    Thought it was a waste to not buy it
    Willing to sell it at no profit or buy a gx3 master or something like that
