Page 11 of 44 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 649
Thread: diagun help
  1. #151
    DK Veteran sergej's Avatar
    Apr 2010
    Latvia,Riga
    " load nk.bin into my Samsung arm9."
    You need start Diagun soft in another device?
    Or restore Diagun?
  2. #152
    Apr 2010
    Latvia,Riga
  3. The Following User Says Thank You to sergej For This Useful Post:
    mmm323 (7th March, 2015)
  4. #153
    Apr 2010
    Latvia,Riga
    Nk.bin Diagun.
  5. #154
    Apr 2010
    Latvia,Riga
    I buy Micro2440(Mini2440) with display 7".Downloads - FriendlyARM
    I made NK.bin 2440 with Platform Builder .
  6. #155
    Mar 2010
    Toronto, Canada
    First Tool to make complete image backup (clone) of my Diagun
    Second I need clone copy of good working Diagun with activesync to reload into mine. If it doesn't work I can always restore my diagun from my image.
    Thanx
  7. #156
    Apr 2010
    Latvia,Riga
    I do not recommended to touch wince5 Diagun!!!
    Loader Diagun format all, NK.bin more 30 M-no stantart wince
    and anather loader no work with him .
    Wince5 Diagun have hidden registry and windows.
    Restore only with programmer damp!
  8. #157
    Mar 2010
    Toronto, Canada
    Thanx Sergej, can you recommend a WinCe Device with bluetooth that will run NK.bin, as a replacement to Diagun handheld.
  9. #158
    Mar 2010
    Toronto, Canada
    I got an orginale diagun to work with activesync even with Win7 and WDM 6.0 no problem easy to connect. Problem is with Chiness clones they have networking and activesync disabled. Basically anything to do with USB communication and a PC is disabled. I have compared files and registry entries and even if you match everything, there is a portion of the program that is in the ROM and Hive registry that you will never figure out.
    Replacement of the ROM chip is the only way to make a chiness clone an orginale Chiness clone LOL. (Who's copying Who).
  10. #159
    Apr 2010
    Latvia,Riga
    Your Diagun have problem in registry with Dial connection.
    Open Start-Setting- Control Panel,Network and Dial,delete connection.
    If not connection-Make New connection "Dial up connection",
    than delete it.Reset.
    Test USB.
  11. #160
    Mar 2010
    Toronto, Canada
    I have tried that ...thank you
    What I have noticed is that tapi.dll is missing in the WinCe windows directory. I can not make copy of file because it's being used in ROM in the emulator or good Diagun. Please can you post copy of file...Thanx
  12. #161
    Apr 2010
    Latvia,Riga
    You can copy dll from emulator when connect ActiveSync.
  13. #162
    Oct 2008
    On Earth
    @sergej
    Hi m8
    I tried to use the Diagun smartbox using my laptop bluetooth.
    And I've got this error
    Please tell me if it is necessary to use just external bluetooth with BlueSoleil?
    Good luck
  14. #163
    Apr 2010
    Latvia,Riga
  15. #164
    Oct 2008
    On Earth
    Yes my friend
    i have an external Bluetooth with Bluesoleil but i tried with my laptop internal blutooth
    I will try with an external bluetooth
    Thanks for your help
    Good luck
  16. #165
    Apr 2010
    Latvia,Riga
    Quote Originally Posted by mattydr67 View Post
    Yes my friend
    Good luck
    You can test without Bluesoleil -post72 http://www.digital-kaos.co.uk/forums...ml#post1310218
    Bluesoleil =china software for china BT.
