You test with big PC or notebook?
WinXP or Win7?
If WinXP -driver Giveio? Post 87 http://www.digital-kaos.co.uk/forums...ml#post1395297
External BT dongle bad work with emulator.
If you plan work emulator -use cable connect-see post 68,185
http://www.digital-kaos.co.uk/forums...ml#post1228360
http://www.digital-kaos.co.uk/forums...ml#post1471521
or HC-05 http://www.digital-kaos.co.uk/forums...ml#post1227619
You can use a usb-serial cable, see post #69![]()
Yes.Emulator work with usb-serial cable.
As i see now (have to clean my glasses ;-)) the smartbox port has a "serial" symbol (i was thinking of some kind of "mini usb")
I see 2x6 pins, is this a combined rs232 and usb port? Are all needed pins (rx, tx,...) on this smartbox port, do you know the pinout? And do you know where to buy the opposite plug, how is it called?
How is the original diagun cable wired?
If i see it right, i have 3 choices to connect the smartbox wired with pc and use emulator:
a) use original diagun cable (i don`t have yet)
b) build such a cable myself (if i find the right plug and pinout)
c) solder a rs232 cable direct to pcb as shown in this thread
Smartbox work only with Com-port! You can use USB-Com adapter.(search as usb serial adapter)
I recommend to do everything slowly - step by step.
1. Run the emulator on a large computer with Com-port.
You can check the emulator without
machine - must give in smartboks 12 volts and test the program Demo. Connect to the points as shown. http://www.digital-kaos.co.uk/forums...help-cable.jpg
. Then you can connect to the machine and check .
Cable length can be 10 meters - I think that you have enough length to connect to the machine with a PC.
Connectors such I have never seen. I saw on sale
Diagun cable for $ 30. It can be cut and altered.
But I recommend to solder directly to smartboks. Connector is small and often breaks.
3. If you like work the emulator you can buy an adapter USB-Com and try on a laptop.
4. I recommend to buy HC-05 the unit it works well.(Bluetooth UART RS232 COM Converter Module+TTL Adapter Daughter Board)
If you have a faulty Diagun - can you unsolder BT modules and work with him.
New Display Diagun !
1.Install X431_SERIES_UPDATE-software Launch for update !
Install this software in your PC ,then install file Display.zip with X431_SERIES_UPDATE in your microSD=
restore your GAG.
Also new Display update your smartbox for new software Launch.
File Display.zip no unpack!
You can see N version Display
Hello Sergej
I have 2 or 3 BT modules from discarded Diagun mainboards,
It has an M (from Master BT), and 9 pins. How can I make it work with my Laptop?
thanks a lot mate
1- 5V
2- PAIR
3- GND
4- GND
5- BT_RXD
6- BT_RXD
7- LED
8- BT_TXD
9- BT_TXD
1- 5V =5V from USB.
2- PAIR
3- GND=pin 5 DB9 com port
4- GND
5- BT_RXD =pin 2 DB9 com port
6- BT_RXD
7- LED
8- BT_TXD =pin 3 DB9 com port
9- BT_TXD
Edit startup emulator Diagun -see post 77 http://www.digital-kaos.co.uk/forums...ml#post1380349
If you use USB-Com adapter -see N your com port in Control Panel-System-Hardware-Device maneger-Port(Com and Lpt).
Thanks mate,
Another doubt, the Bluesoleil soft recognize it? or should I do something extra?
thank you very much Sergej
Maybe out of the topic, but do you know a PDF reader for the Diagun and how to install it (The device not the emulator)
thanks and sorry for my bad english
Bluesoleil soft -only for USB BT dongle.
For BT modules from discarded Diagun or HC-05 only set
N your com-port in emulator.
PDF reader in FileViewers.rar.
Unpack in Storage Card and use.
