drugowaz (28th July, 2021)
Hmm. Dont checked. I looked at fccid only. Same all. I resheled new case to him. Old in garbage,will check tomorow
Checked. All identical
Letter A ,fccid etc same
Hello drugowaz and all other Toyota skilled people! Did you manage to solve the Prius problem? I am in the exact same situation. My client have 2 Prius cars 2005/2006 both with slot key and keyless that needed one new spare key each. Immo programed without problem, but I could not program keyless function or even remote. Tried manual for remote programming and lock cycle 2 times for the new key but accept original key right on. Tired by OBD with AVDI and Autel (kwp2 keyless) not work, take original but not the new one.
Two Prius, two second-hand keys (same number part number and letter A on all keys on battery hatch), what am I doing wrong?
I have not reset any ECUs, client have one master key to each key (or do I need to reset the smart ECU even for spare key programming)?
I hope for some help, spent 3 hours with no luck.
Thank you!
Ok guys my son Allex just called me with the same problem.. He wanted me to give him the answer so he can get paid, no pressure. I gave him the Toyota text book method he had 4 programmers all failed to programmed 2 different Smart silver back. He just called me with his final thoughts, should have change the battery in the refurbished Proxy. Aftermarket Smart did not take, I will be getting the Transponder ID to share. I do that to follow the trail. I had a batch of 50 aftermarket that share the transponder ID. I could never add a second in that state.
Weasel3 (8th February, 2022)
I have seen them where you have to do a immo reset and put your key in first then the original...
