Results 1 to 3 of 3
    Newbie giegaand1's Avatar
    Aug 2018
    Default any solution for Bytes flipping-swapping
    Hello, looking for help. Can somebody point me to the right direction, been looking for soft to make one simple task, swap bytes like in picture 1 swap to 2, then 3 swap with 4 and 5 with 6 and etc. Like in picture D0 swap with 80, B0 swap with 10 and so on. Online solutions doesnt work, tryed HxD, FlexHex, HexEditor Neo there are no option like i need to flip bytes. Any advice on scripts or soft or any kind of info would be helpful. Thanks
    Hit like and thanks if I've helped you!!
    Work HARD and never never never give UP !!!
    Meat-Head's Avatar
    Yeah there is a utility on this website written by DK member
    if you read dump as 8 bit will swap to 16 bit and vice versa
    when you find it add t’ link in here
    Aug 2018
    Found few options: Jtag from smok does it and very easy to use, from menu option "swap". Also soft "Elnec PG4UW" lots of functions and swap works like charm. Carprog does it as well, tested, easy to use.
