Results 1 to 2 of 2
    Apr 2021
    Default Audi A6 4F ECU Swap
    I need to swap a partially defective ECU in an Audi A6 4F.
    I have VCDS and some OBD adapters and so far I figured that I must find out the PIN of the ECU which can also be found in the EEPROM dashboard. Is that correct?
    VCDS is not able to do that, what else do I need to read the PIN and swap the ECU?
    Adresse 07: Anz./Bedieneinh.        Labeldatei: DRV\4F0-910-7xx-07-H.clb
       Teilenummer SW: 4F0 910 732 H    HW: 4E0 035 729
       Bauteil: Interfacebox    H43 5140
       Revision: 00000000    Seriennummer: 350IU047534819
       Codierung: 0000301
       Betriebsnr.: WSC 00000 000 08192
       VCID: 28583D3E9B20190FCE-807D
       Subsystem 1 - Teilenummer: 4F0 910 609
       Bauteil: Bedienteil MMIC6H07 0870
    Thank you so much in advance
    Kind regards
    MAK
    Apr 2021
    I also have a VAG-K+CAN Adapter, but it looks like I do not have the right software to read the EEPROM, as the file I got looks wrong. Well maybe it is just encrypted, but I can not see any VIN or other strings that I saw in other EEPROMs on DK.
    Which software version am I going to need for this?
