I need to swap a partially defective ECU in an Audi A6 4F.
I have VCDS and some OBD adapters and so far I figured that I must find out the PIN of the ECU which can also be found in the EEPROM dashboard. Is that correct?
VCDS is not able to do that, what else do I need to read the PIN and swap the ECU?
Adresse 07: Anz./Bedieneinh. Labeldatei: DRV\4F0-910-7xx-07-H.clb
Teilenummer SW: 4F0 910 732 H HW: 4E0 035 729
Bauteil: Interfacebox H43 5140
Revision: 00000000 Seriennummer: 350IU047534819
Codierung: 0000301
Betriebsnr.: WSC 00000 000 08192
VCID: 28583D3E9B20190FCE-807D
Subsystem 1 - Teilenummer: 4F0 910 609
Bauteil: Bedienteil MMIC6H07 0870
Thank you so much in advance
Kind regards
MAK
