correct and code is Z4521
regards
Lads got Astra H on a 2005 tried picking locks no success I ended removing driver door lock and stripped the lock to read wafers numbers but need your help please, the lock wafers read as follows.
From number one each wafers 12-2-11-1-13-1-12-4.
I presume the cut numbers will be 22113124 can someone confirm car about 36miles if not I will have to order key code from dealer thanks in advance.
Note:All information given is to be used for educational purposes only and should not be taken seriously.
regards
super jumbe (7th May, 2021)
Always two numbers, followed by a separate number, one for the top wafers and the other for the bottom wafers , and for cutting number (1 black) is ignored.
12-2-11-1-13-1-12-4 A number with two digits, always take the second number for cutting
This method can also be found in different types of vehicles, where you will sometimes find letters and numbers as well.
https://www.uhs-hardware.com/product...ination-system
Opel is 8 wafer.
This is 10 wafer.
But maybe there will be the same for 8 wafers in the future.
