Thank you so much . I have a colleague who uses zedfull with him can I solve?
Related to yours thread. VVDI have option to backup HFM module flash file from D70F3633. Next time, first remove HFM open it and do backup. After that use Renolink. Because with Renolink or Reno ecu tool to be able to add new key card you need pin code. Pin code is located in HFM, to read HFM, Renolink, i do not know what do it with HFM module flash, put in boot mode or clear some data, i do not know. But whatever software do it, you can always restore it from backup. My opinion is that is nothing wrong with yours UCH than with HFM.
So what should I do now? Does Zedfull solve anything?
If I get the original PIN, can I program and start the car?
I think no. First you need to repair HFM module. But let some other member give you better advice.
ok thanks, hope someone help me
Maybe you have make the hfm module virgin.
Then you need to learn the hfm back to car.
for this job you can use Renault Ecu Tool.
If you want to buy i can arrange one for you...
When I help you
PUSH on +THANKS and REP or
davideopel (10th May, 2021)
It is on offer at 490 euros. But I have to fix it right away I look for who has ret in my area
thanks for the reply, i'm trying with a passthru tool to connect to the renault network because i don't have renault ecu tool
