Louislesinge (10th May, 2021)
I'm not sure of anyone will be willing to help with this just like that for free but there is a lot different amazing kind of help in this forum so why not, let's try.
So Renault Ecu Tool with newest update, is able to virgin that rare 3 button HF card. R.E.T software is only needed to generate new data from card eeprom, so all we need is any eeprom programmer and some hitag2 programmer + R.E.T software for calculation only.
This is manual for this process http://www.immo-tools.lt/site/files/...74Ph2_Card.pdf
Are there some R.E.T users who might help with this? Some sellers already sell unlocked card after R.E.T virgin them but still high price.
For trusted members i can help.
I see the manual is very clear How to.
To read 25040 in circuit, many programmer can do. It mention DO NOT connect pin8 from programmer and connect 3v battery to card.
With 25040 data, you can get ISK from RET to Unlock original PCF7936 by Hitag2.
Or If you change 7936, just fill ID then save Virgin data for 25040 and write back.
I think if we have no RET, just read 25040 and ask for help who has RET to virgin the dump.
Yes true very easy job.
Renault ecu tool can't do beter instruction on this work.
Envoyé de mon LYA-L29 en utilisant Tapatalk
Yes I´m in this boat to...
For trusted members I can help...
p1et (9th May, 2021)
I do not quite understand what is required, but apparently you need to unlock the file. create a separate theme, download the eeprom and the ret owners will do. I don’t know how much you need to be greedy, so as not to help a person in need
I’ve desolder 25040 from pcb and I can’t read it properly
Ive Full 00 in dump I don’t know why
I have solution for that from over 1 year. But i spend too many hours and money to solve it.
Price will be always high becouse cards used are rare and not cheap + unlock is not so easy + even some cards in good shape can be defective (thats why i am not selling them - only using for my clients). But all for unlock is read chip and engage it with pcf.
here is a clean file made ret
enter the transponder ID data in address 180-183 and record the received eeprom in 25040. I don't have cars to check if the card works. but I think many of you can do it. Thank you
dijo (9th May, 2021), Domi (10th May, 2021), godfathertwo (10th May, 2021), kemaster (12th May, 2021), lion0304 (9th May, 2021), Louislesinge (10th May, 2021), P&D (17th May, 2021), p1et (10th May, 2021), Zaklberg (2nd August, 2022)
Can anybody help me with virginizing a 3 button card uk only
Please I am a trusted member I have changed my email send two emails to administrator I had to register with different user name till get sorted orig godfathertre thank you.
