Results 1 to 3 of 3
    Mar 2016
    EU-PL
    Default Peugeot 1.8 to 2.0 swap / has been started
    Hello All!
    May be im not new here and a post bouncer, but im a member here and like to ask You some questions...
    im trying to connect a engine witch engine wiring from Peugeot 2.0 to BSM and from BSM to BSI but the wiring from BSM to BSI is from 1.8 engine.
    I made some wiring diagram and new wiring harness and i cant get the engine start, not cranking and no fuel pump/relay starts.
    I think i need to make the engine first IMMO off first to play more.
    First question is can i use a xprog to read the ecu IAW 6lp1.45 (does anyone have a xprog pinout for it ?)
    the PCB is different as i could find on the net..
    i found similar pcb on net but i dont think it will work, not for a reason layout is different, and the model no of the electronic is different..
    http://www.auto-bk.ru/forum/topic/63...D%D0%B8%D1%8F/
    Mar 2016
    EU-PL
    any one knows anything about this ecu connection to xprog ?
    Oct 2016
    use ktag works great
