Results 1 to 8 of 8
    Sep 2014
    Somewhere
    Default Pin from eeprom ECU neede on EDC15C7 Opel
    Hi to all!
    Please help with PIN code from eeprom 95080 EDC15C7 opel.
    I need to swap these two ECU.
    Thanks!
    kiszka's Avatar
    Quote Originally Posted by Jashmine1983 View Post
    Hi to all!
    Thanks!
    org pin 3742
    scrap pin 1194
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  3. The Following 2 Users Say Thank You to kiszka For This Useful Post:
    Jashmine1983 (9th May, 2021), sanchos (15th September, 2023)
    Autronico2's Avatar
    Jan 2021
    Italia
    Hi to all!
    Thanks!
    Why don't you directly move the eeprom of the original ecu in the used ecu, so you also transfer the original pin code.
    kiszka's Avatar
    Quote Originally Posted by Autronico2 View Post
    because these are not identical ECUs, this is what only an amateur does with this car
    when programming takes 15 minutes and is a 100% certainty
    Reality of life :
    4:Everyone lies
  6. The Following User Says Thank You to kiszka For This Useful Post:
    Autronico2 (9th May, 2021)
    Autronico2's Avatar
    Jan 2021
    Italia
    Quote Originally Posted by kiszka View Post
    A ok, I have not downloaded the files, I did not understand that the ecu were different.
  8. #6
    Sep 2014
    Somewhere
    The ECUs are the same....I've tried to reset ECU with OPCOM but it does not work..... the PIN CODES are good.
    When I enter the one from scrap on car it says "please wait", and freeze...I've also tested with power source on car.
    I'm going to swap eeprom ans see what happens.
  9. #7
    kiszka's Avatar
    my friend, the numbers don't lie, written in eeprom
    See what is the time delay of the ecu
    Reality of life :
    4:Everyone lies
  10. The Following User Says Thank You to kiszka For This Useful Post:
    Jashmine1983 (14th May, 2021)
  11. #8
    Sep 2014
    Somewhere
    Swaped eeprom and worked....thanks!
