Results 1 to 10 of 10
Thread: bmw ms43 !
    May 2019
    Default bmw ms43 !
    hello guys I am looking for file with ews off ms43 325i e46 why? I do myself in tunerpro and make a immo bypass but no crank so to be sure I one more time try write file from you guys and see what happens because I think this ecu is dead, If I turn a key I hear a fuel relay.
    I think ecu don't have propely ground or something like that anyway like I said I am looking for file with ews off for double check.
    I will be very grateful for any help.
    regards
    Sep 2018
    Add your file ,we will check.
    May 2019
    here you are
    Sep 2018
    I already have
    Sep 2018
    The changes to the file looks good.
    The cheksums are correct?
    Ews is it removed from the car?
    May 2019
    yep I think this is ecu problem
    Sep 2018
  8. The Following User Says Thank You to erkor For This Useful Post:
    dzejkoff (13th May, 2021)
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Default bmw ms43 !
    No crank?
    Did you conect 1 and 3 pin on ews plug?
    It must crank . Look at pins on ews that you have. 50 (+12v) while cranking on pin from ignition lock
    Maybe you got bad ignition lock.
    It must crank when ews is bypassed.
    Maybe starter or ignition lock is bad.
    Here to HELP!
  10. The Following User Says Thank You to immokill For This Useful Post:
  11. #9
    May 2017
    Right. Such with removed ecu and bridged wires starter must run.
  12. The Following User Says Thank You to Lambda1 For This Useful Post:
  13. #10
    May 2019
    Thanks guys for reply already buy ignition cube I check stater and starter is good I open and clean inside after that i put copper grease In some specific location.
