both files are bad. DTC faults turned off not correctly (addresses are bad.). Why turned off Exhaust temp sensors faults? If you have bad sensors, DPF regeneration will not work. And orig file have strangers modifications.
By the way if you have problems with checksum when writing ecu with KTAG or KESS, you need to update Framework. You will find info in forum or internet.
