Results 1 to 8 of 8
    Feb 2018
    Default Help to CLONE sim4lke
    Hi I would like to have some advice on how to clone the aforementioned ECU.
    let's start with the main information, which label code should I take into consideration to buy one that fits my car?
    thank you .
    May 2017
    HW Number.
    Which tools you got?
  3. The Following User Says Thank You to Lambda1 For This Useful Post:
    robertogo (11th May, 2021)
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by robertogo View Post
    thank you .
    SIM4L KE
    5WK90526
    A2711538579
    A0014466902
    take car that all numbers fit...
    you can open them and transfer flash by soldering, immo all other data are in flash...
    or reset new used unit by a mercedes tool like cgdi/vvdi and so on without opening and adapt it by DAS or vediamo...
  5. The Following User Says Thank You to figani For This Useful Post:
  6. #4
    Feb 2018
    Thanks for the replies!
    I try using mpps v18 by attempting a boot mode.
    a guy did the clone in boot mode with kess.
    so doing a complete read and write of the flash should succeed
    Feb 2018
    I, have tried to clone it in boot mode
    with mmpps v18 in bench . When i tried to write clone file its do erasing flash and an error , now flash is empty , mpps read empty flash and kess not read ecu
  8. #6
    Feb 2018
    Please help me
  9. #7
    May 2017
    Ori ecu is empty?
  10. #8
    Feb 2018
    I have solved, i write ecu with file read in full with mpps and i write it with kess
