Corsa D 1.3 CDTI 2008
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Oct 2020
    uk
    Default Corsa D 1.3 CDTI 2008
    Hi guys, long story short
    Iíve got an corsa d 1.3 2008 Z13DTJ ecu water damaged.
    Is there any possibility to change all kit (BCM, ECM, cluster , airbag ecu) with a different ECU kit? My one itís an Magneti Marelli and the other one itís a Bosch. I think the Bosch kit came from the same year corsa d but A13DTC engine..
    Oct 2018
    11
    Connects to the diagnostic device?
    Oct 2020
    uk
    No... eeprom on original ECU missing
    Oct 2018
    11
    You have to buy the same and program the Z13DTJ Opcom
    Oct 2018
    11
    And there is communication with the car at all, because it should be without an ECU with everything except the engine
    Oct 2020
    uk
    I just donít understand... Iím not after swapping the ECU, I want to change everything from another working car (bcm, ecm , airbag module, keys, ignition, etc..) why do I need to program anything???
    Oct 2018
    11
    You need to buy a magneti marelli set as it was with the engine code you had
    Oct 2020
    uk
    This is what Iím trying to understand, why I need to put exactly the same set?? What exactly will not work??
    Oct 2018
    11
    You have read this driver once, because you see a resistor that you desolder before reading, it can be in four different places and the car will not start because this is how the installation is done and then there is a different engine power
    Oct 2020
    uk
    Mate, Iím not about to desolder any resistor and not do any readings ...
    Iím just about to CHANGE all components forming the immo system (ecu, bcm, airbag ecu, key, barrel, lock) from another running car...
  11. #11
    Aug 2008
    88
    then do as said otherwise replace engine too for the same engine that the kit uses
  12. #12
    Member bendy's Avatar
    Mar 2009
    Essex, UK
    108
    Hi prodbecks,
    You need a matching ECU, your is 13DTJ engine & you get a kit off say, 13DT you may not have 100% running car.
    There are many differences between engine components & the ECU itself depending variant.
    The Bosch kit no good you have Magneti Marelli (Engine code Z13DTJ) & not A13DTC <---Different variant, system.
    Hope that helps you understand better.
    However this ECU is vary easily repaired from water damage, I have never failed yet with this ECU.
  13. #13
    Aug 2008
    88
    depends on the extent of the damage
  14. #14
    Oct 2020
    uk
    Tanks for the info bendy, unfortunately my ecu has no eeprom chip at all, it was missing so no chance to repair it...
  15. #15
    Aug 2008
    88
    eprom you can replace with a new one then program it to car
